December 3, 2022 at 2:02 pm
jannatul nayem
SubscriberHow will i put the analyte in spr senor?will it work if only i change the bacground index
December 19, 2022 at 9:01 pm
Guilin Sun
Ansys EmployeeThis would be the environment, or something to surround the sensor. Think the scenario how to use this sensor in experiment?
- Error on Lumerical device
2534
2066
1285
1104
459
