December 20, 2017 at 7:55 pm
bushrar
SubscriberHello,
Usually after running a simulation with cylindrical capillaries I usually check to see that there is only a slight difference between ANSYS calculated pressure drop through the capillary vs. the analytically calculated pressure drop(in the case of constant viscosity using Hagen Poiseulle: ( deltaP= 8*L*Q*visc/(pi*r^4)) . I was wondering how to analytically check a geometry using a capillary with a slanted entrance as shown below:
December 21, 2017 at 4:06 pm
raul.raghav
SubscriberI doubt if you'll find an analytical relationship for the case you're looking at. And based on the image of the geometry and a rough visual estimation of the length (L) and radius (R) of the capillary, I'm sure Hagen-Poiseuille equation would not apply for your case (L needs to be >> R, so the flow is fully developed).
2600
2088
1319
1108
459
