Preprocessing
Preprocessing
Analyzing performance of an annular gas turbine chamber
    • Thabo
      Hie guys l'm receiving a message that is saying "The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem."
      I am not sure how well l can fix the problem. please assist
    • Karthik R
      Administrator
      Are you using the Fluent meshing with Watertight geometry workflow?
      Thanks.
      Karthik
    • Thabo
      No l'm not. Do you recommend l use it?
    • Keyur Kanade
      Right click on error and select go to geometry. It will show the location.
      Please modify geometry at that location. Or change mesh sizing at that location.
      Then regenerate the mesh.
      Keyur
Viewing 3 reply threads
