3D Design
3D Design
Angle of attack for upper wing
    • tyw7
      How can I insert an angle of attack for the upper wing?
    • Keyur Kanade
      Use  Sketch --> Dimension --> Angle
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_dm/agp_2dsketch.html
      Or
      After generating geometry in 3d, you can rotate it.
      Keyur
    • tyw7
      Will that rotate the top wing only?
      And I can't view your link.  Can you post a screenshot?
      If it's a separate sketch, yes. The link is to the Help system, go to DesignModeler Help and look for the section on 2d sketches.
    • tyw7
      The wing was inserted as a curve and was patterned and translated from the lower wing.
    • Keyur Kanade
      Can you please explain more.
      What is 'wing was inserted as a curve'
      Did you insert curve and then created surface?
      If you have a surface or solid body, you can use translate / move command.
      Please check following about how to access help.
      Keyur
Viewing 5 reply threads
