Angular Dependency for Reflection at Opaque Walls
    • aleo
      Hi everyone,
      I am simulating a 3D-DOM Radiation problem, in which I have an Opaque BC, which is partially absorbing (emissivity=0.3) and reflecting the rest (0.7) specularly.
      My question is, if I can define an angular dependency for these values, by using a built-in expression/function. For example a ray coming with an angle of 30° has other values than a ray hitting my surface at 80°.
      Thanks in advance, and kind regards, Leo
    • Karthik R
      Administrator
      If I understand your question, do you wish to modify the percentage of emissivity and reflectivity based on the incoming angle of the ray? I do not think this can be done, not at least using an expression.
      Thank you.
      Karthik
