animation in PST
    • ofrik
      hello,
      i have a simulation of air flow inside a sertain pipe i need, when the inlet velocity varries in time.
      i created an animation of velocity contours and vectors pre calculating.
      i can see the animations in the set up app but not in the post processing app, does anyone know why is that?
      i want to create a movie file.
      thank you !
    • DrAmine
      Timestep animation or key frame is required . Ensure that you loaded the last data file in Post.
    • ofrik
      Hi, i still have the same problem. i definitely loaded to PST the last data file, and still cant see the animations i created in FLUENT.
    • DrAmine
      you won't see what you have created in Fluent inside CFD Post: there are two different programs
Viewing 3 reply threads
