Animation of Steadt State Thermal Simulation
    • Awlad
      Dear Support Engineers:nI am doing a steady state thermal simulation. At the end, I am getting temperature plot (using PLNSOL, TEMP command). Is it possible to see the animation? I mean how the temperature is changing within 1 second time? I tried to find this option under Plot Control, but I was not successful. nAny comments or suggestions will be highly appreciated. Thanks,nAwlad.n
    • 1shan
      Hello ArraynA steady state analysis would be a wrong choice for your problem, since it does not tell you how the temperature varies with time rather gives you the final temperature distribution after an infinite time. You should use the transient thermal solver instead.nCheck out these tutorials https://courses.ansys.com/index.php/courses/heat-transfer/lessons/homework-quizzes-simulation-examples-overview-of-heat-transfer/nRegards,nIshan.n
    • Awlad
      Many, many thanks.nAwald.n
