March 14, 2021 at 11:16 am
za36kuzo
SubscriberHello everybody,
I am simulating unsteady flow. I create injection file in MPM model. It is looking good. As next after I create and display the particle, I should define the animation sequence, which should be opened from the Solution Animation dialog box, and this allows me to define what each sequence displays. So, the problem now I could not fine the animation sequence in the calculation activities dialog box as seen in the below images. Also the animation dialog box doesn’t show me any sequence animation command.
I wonder if I have to add another command or any procedure to make the sequence animation dialog box available.
Thanks in advance.
March 15, 2021 at 4:34 amKeyur Kanade
Ansys EmployeeYou need to create object and then select that object to define animation. Then run the solution.
Please check
Regards Keyur
March 18, 2021 at 11:10 amza36kuzo
SubscriberThank you Keyur! That solved it.
March 18, 2021 at 2:59 pmDrAmine
Ansys EmployeeWelcome!
2630
2104
1329
1110
461
