December 2, 2022 at 8:31 pm
Maralll
SubscriberDeal All,
My model is a hemisphere and the I want to consider the material as anisotropic hyperelastic. I would like to have the directions of my anisotropy in circumferential and pheripheral direction. To my knowlege, I guess I need to somehow consider either the element coordinate systems (follows the named directions) or shperial coordinate sytem so that I can assign these directions in my material models. The elemet directions (imge bellow) that I were able to generate doesn't show my desired direction for material.
Also, the micro that I am using currently to consider the anisotropis hyperelasticity in ansys workbenck is follows:
TBDELE,ALL,matid
ESYS,0
TB,ahyper,matid,1,10,exp
TBDATA, 1, 0.08 ! A1
TBDATA, 2, 0 ! A2
TBDATA, 3, 0 ! A3
TBDATA, 4, -0.0625 ! B1
TBDATA, 5, 0.0 ! B2
TBDATA, 6, 0.0 ! B3
TBDATA, 7, 0.055 ! C1
TBDATA, 8, 750 ! C2
TBDATA, 9, 0.055 ! E1
TBDATA, 10, 750 ! E2
TB, AHYPER, matid, 1, 1, PVOL
TBDATA, 1, 0.1 ! D
TB, AHYPER, matid, 1, 3, AVEC
TBDATA, 1, 1
TBDATA, 2, 0
TBDATA, 3, 0
TB, AHYPER, matid, 1, 3, BVEC
TBDATA, 1, 0
TBDATA, 2, 1
TBDATA, 3, 0
MP, DENS, matid, 1e-09
csys,0But again, I know the directions are not as I want and I need to define thoese directions somehow.
I would appreciate any help.
Sincerelly,
Maral
December 3, 2022 at 2:08 pm
bhagwantP
Ansys EmployeeHello,
Will you please clarify bit more about when you say that elemet directions that you were able to generate doesn't show desired direction for material with respect to circumferential and pheripheral direction?
December 5, 2022 at 5:52 pm
Maralll
SubscriberIdeally what I would like to reach in fiber directions is like this photo (If we look at the top view). There are orthogonal fibers and also in an annulus in the bottom of the hemisphere, there are circumferential fibers. So, I would like to model this kind of anisotropy by defining the fiber directions in some way.
I can also consider the fiber directions like the following image if I simplify my model:
Bellow is another image showing this fiber directions:
I would deeply appreciate your time.
Maral
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2524
2066
1285
1096
459
