December 7, 2019 at 8:12 pm
camarajoe
SubscriberI am trying to simulate an inductor out of a ferromagnetic anisotropic microwire core material. I set the material as cylindrical
with relative permeability in Z direction T(3,3). for X and Y I set the relative permeability to act as air. I am trying to make sure it is simulated properly. The magnetic field vector plot is attached.
December 11, 2019 at 8:51 pm
Paul Larsen
Ansys EmployeeIt is very hard to tell due to the density setting of your vector spacing and that we see all the vectors in the X-direction stacked on top of eachother. Overall, it looks like the fields outside the material might be correct, but I don't have enough visual information to see if the fields are good inside.
I did a quick test with the material settings the way that you described, and it looks good. It is definitely a different response than just an isotropic linear permeability like the generic "ferrite" material. There is much more preference for the Z-direction.
- Maxwell, HFSS or Q3D?
- Error
5340
3345
2471
