ANISOTROPIC MATERIAL in Ansys APDL? which elements types are allow it for Annisotropic Material APDL
June 25, 2021 at 8:57 pm
disotop
SubscriberHi Everyone, Can anyone help with how Ansys transform the coordinate system of the Annisotropic material defiine in ANSYS APDL when I use a Local Coordinate System to the elements of the model?
The thing that, I have read lots, every single Manual of APDL but Any of them saids if Ansys Actually do a transformation fo the coordinate system that I use for introducing the Anisotropic material for the Local Coordiante System give to the elements,
How I can check what is ansys doing ? another question , which type of element are allow it for doing simulation with an anisotropic material?
June 28, 2021 at 2:36 amKeyur Kanade
Ansys EmployeeViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2508
2064
1279
1094
456
