Anistotropic orientation rotation
    • PureInsanity
      I am trying to work with Anisotropic material at different crystallogrrphic orientations, like [100], [010], [111], etc. I would like to figure out how I can rotate this orientation in such directions if not any direction. As far as I understand in Gen 0 code, you can set angles and play around with material properties to achieve this. How would I usually do this in ANSYS mechanical or Workbench?
    • Sandeep Medikonda
      Looks like you asking how you can rotate the material and keep the default element orientation.  We don't have a tool to do that.
      You can, however, set an element coordinate system by defining a global x/y/z aniso material and rotate the element cs's.
      Refer to the help on how you can do that:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/wb_sim/ds_element_orientation.html
      there are also other helpful discussions on the forum you can refer to:
      Discussion 1
      Discussion 2
