Ansys Products
Ansys Products
ANSYS 17.2 License not Available for Coupled Solver
    • AdamCU
      Hey everyone,
      I'm attempting to run a coupled fluid-structure analysis with ANSYS Workbench 17.2. I have licenses individually for Fluent and Mechanical, but even though the Fluent and Transient Structural runs work fine on their own, when coupled using the process described here (Part 1:
      ; Part 2:
      ), they error out as shown:
       |                 System Coupling Co-Simulation Summary              |
        Participant : Mechanical APDL (Solution 1)
         Version/Build Info    = Mechanical APDL Release 17.2     UP20160718
                                   DISTRIBUTED WINDOWS x64  Version
       Participant : Solution
         Version/Build Info    = ANSYS Fluent 17.2.0, Build Time:Jul 27 2016
                                 119:44, Build Id:10113, OS Version:win64
       |                              NOTICE                                |
       | An exception has occurred and has been transmitted to the coupling |
       | participants.  These participants have been disconnected from the  |
       | coupling service.                                                  |
       |                      System Coupling Exception                     |
       | Origin            : Airflow (Solution)                             |
       | Error Code        : 2                                              |
       | Error Description :                                                |
       |   Fluent encountered fatal error after sync point Analysis         |
       |   Initialization: CFD Solver license [ANSYS Academic Research      |
       |   Mechanical and CFD] is not available for coupled run             |
       System coupling run completed with errors.
      Attached is an image of the runtime errors we get during the co-simulation process.
      It seems that there's an additional coupled-simulation license required for this type of co-simulation? If so, does anyone know how we can obtain this license?
      Thanks a lot
    • tsiriaks
      Can you try launching User License Preferences v172 (make sure all ANSYS GUI's are closed) -> then select 'Use a separate license for each application' .
      Do you still get the same error ?
      Thanks,
      Win
    • AdamCU
      That did indeed fix the problem! Thanks a lot!
    • tsiriaks
      that's great ! you are welcome. Glad it helps.
      Thanks,
      Win
Viewing 3 reply threads
