October 18, 2018 at 12:27 am
OGUZHANOGUZ
SubscriberHi,
I have downloaded Student 18.2 . My OS is Win 7 Pro. However, setup.exe does not respond. Wheel turns then disappears.
October 18, 2018 at 12:35 am
Sandeep Medikonda
Ansys EmployeeHello,
Can you make sure that your username does not have any special characters like "?" etc. or spaces?
If that doesn't work try a reset of Windows Update components as suggested in this article.
Sandeep -
October 18, 2018 at 4:29 pm
tsiriaks
Ansys EmployeeHi OGUZHANOGUZ,
Aside from Sandeep's suggestion.
If you keep monitoring the Task Manager (from when you start running setup.exe to when the wheel disappears) , does setup.exe show up at all at some point ? If it doesn't show at all, it might be worth to try temporarily disable any kind of antivirus or security software on the machine. Or you can try installing the software while you are on the Windows safe-mode.
You can also try silent install too. Open elevated CMD Prompt (right click on CMD Prompt icon, then 'run as administrator') . Change your directory to the unzipped installation package folder, then issue the following command
setup.exe -silent
Thank you,
Win
October 25, 2018 at 12:18 pm
October 25, 2018 at 4:40 pm
tsiriaks
What is the error during the installation ? Please post the content of the 'install.err' file under (default installation location) C:Program FilesANSYS IncANSYS Student
Then for the 'graphscene' issue, you might also try resolutions from here
https://forum.ansys.com/forums/topic/installation-problem-in-workbench-19-2/
Thanks,
Win
October 26, 2018 at 7:46 am
OGUZHANOGUZ
SubscriberAfter I changed pc user name with English characters it worked finally. Thank you for your great support.
October 26, 2018 at 4:20 pm
tsiriaks
That's great ! Thank you for the update.
Could you mark the post as 'Is Solution' , so that we know this thread has a resolution and is closed ?
Thank you,
Win
- Workbench error
- Workbench not opening
- License Error
2630
2110
1335
1110
461
