Ansys Free Student Software
ANSYS 19.0 Visual studio + Intel parallel studio XE version required for UPFs?
    • SamKleespies
      I am trying to implement a UPF into ANSYS 19.0, however I need to be running the correct version of visual studio and parallel studio for the correct fortran compiler version. The platform support plan for ANSYS 19 (https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/platform-support-strategy-and-plans-19.pdf?la=en) says that in ANSYS 19.1 visual studio 2015 and Intel parallel studio XE 2017 will be needed, however I need to know which versions are needed for ANSYS 19.0. Can anyone help me with this?
    • raul.raghav
      I'm not sure if you've already found a solution to your problem, but still posting this for others having trouble.
      Attached is a screenshot of the compiler compatibility provided in the Ansys Installation Manual for different Ansys release.
    • Vishal Ganore
      I am using VS community 2017. Please see here for additional details: https://studentcommunity.ansys.com/thread/problems-loading-udf-for-moving-mesh-in-fluent/
    • juan.rojas
      Are you using VS Community 2017 with which version of Ansys? 19.1?
    • brocktree
      Does Ansys Student version support UPFs?
    • Max Power
      I would very much like to know the same thing. Sofar I couldn't get the customization files from the installation and without those it doesn't seem to be possible.
      If you mean UDF's then yes they work in the student version. You'll need to download a compiler unless you interpret the code.
    • vidyadhar.kpm
      Hello Vishal,
      I am unable to launch fluent using x86_x64 cross tools command prompt.
      The message says:
      launcher1.exe has stopped working
       A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
      It gives two options :  1) Debug 2)close program
      If I chose Debug, it takes me to VisualStudio and asks for permission to debug launcher1.exe
      My Ansys version is 19.2 Academic. My desktop has Windows 7 installed on it.
      i have downloaded Visual Studio 2019 community version. Should I use VS 2017 instead?
      Thanks in advance!
      vidyadhar
    • JakeC
      Hi vidyadhar,
      Yes please use 2017 instead.
      Thank you,
      Jake
    • Mn65
      Hi Raul
      Do you think the Ansys Mechanical Student version support UPFs? or it is necessary to have the ANSYS enterprise? please see the  GUIDE TO USER-PROGRAMMABLE FEATURES |,
      Chapter 1: Understanding User Programmable Features (UPFs)
      Thank you.
      Marzieh
    • cnac
      HellonnI am using ANSYS 2020 R2 and need nMicrosoft Visual Studio Professional 2017 Version 15.0 (including the MS C++ compiler), Intel C++ 2019.3.203 and Intel Visual FORTRAN 2019.3.203 compilersnFor my coding in Workbench can I just use icrosoft Visual Studio Community 2017 Version 15.0 (including the MS C++ compiler)? Do I need rest of the compilers? Does anyone have a link for the Intel C++ 2019.3.203 and Intel Visual FORTRAN 2019.3.203 compilers?nThank youn
Viewing 10 reply threads
