January 17, 2023 at 10:03 pm
January 23, 2023 at 4:05 pm
rainwadj
SubscriberAny ideas on this?
January 24, 2023 at 3:43 pm
Mike Rife
Ansys EmployeeHi rainwadj
Please explain, in detail, the workflow you followed that led to this traceback. Which Ansys product are you using? If Workbench Mechanical which solver? What is the OS of the computer and is it supported?
Mike
January 24, 2023 at 4:29 pm
rainwadj
SubscriberThe system is running CentOS 7.9. The researcher who reported this error says:
"This error occurred when attempting to run v19.2 Ansys Mechanical with Workbench. My Workbench project consists of a single Static Structural analysis system. Everything is configured correctly (e.g., valid Geometry, Mesh, boundary conditions, etc) in the system. However, if I attempt to 'Update' the Solution cell of the system in the project schematic OR open the Mechanical application itself and solve there, Workbench reports an 'error updating the Solution cell' and several messages are given (error updating, check solution output, etc). However, there is no error reported in the solution output file. Only the aforementioned error in the terminal appears. I hope this helps."
January 24, 2023 at 4:36 pm
Mike Rife
Ansys EmployeeThat is probably way too different of a CentOS version for WB version 19.2. Back when 19.2 came out CentOS 7.2-7.4 were supported. See here if you need to "prove" the point: https://www.ansys.com/content/dam/it-solutions/platform-support/previous-releases/platform-support-by-application-192.pdf
Can they update the version of Ansys they are using? Or roll back to an earlier, supported OS version?
MIke -
January 24, 2023 at 4:39 pm
rainwadj
SubscriberI have another thread open here regarding version 22.2. If we could get that resolved, then they wouldn't have a need for 19.2 anymore.
February 2, 2023 at 7:35 pm
rainwadj
SubscriberAny more ideas on this?
February 2, 2023 at 7:46 pm
Mike Rife
We can try the following; in Workbench select Tools -> Options; in the Options window select Mechanical on the left. Is “Enable Legacy Solve
an option with a check box? If so check it on. If not select Appearance in on the upper left (in the Options window) then scroll down and turn on beta options. Ok out of the Options. Then open it (Tools -> Options) again and go the Mechanical on the left – now is ‘Enable Legacy Solve’ available? If so check on and ok your way out. Now try the solve and post what happens either way.Mike
- Workbench error
- Workbench not opening
- License Error
2702
2138
1355
1144
462
