Ansys Free Student Software
ANSYS 19.2 R2 FLUENT opens and hangs and sometimes doesnt open at all
    • helpme
      While using workbench in Fluid Flow(fluent) , Fluent doesn't open or hangs upon opening
    • tsiriaks
      This seems to be stuck while it's trying to launch MPI processes.
      Checkout suggestions in this thread
      https://forum.ansys.com/forums/topic/fluent-application-failed-to-start-2/?
    • helpme
      i tried those methods, but they didnt work i keep getting this message at the end
      Host spawning Node 0 on machine "DESKTOP-3F5U06C" (win64).
      WARNING: No cached password or password provided.
               use '-pass' or '-cache' to provide password
    • tsiriaks
      What if you open CMD Prompt, then use the following command
      "%awp_root194%fluentntbinwin64fluent.exe" -r19.4.0 3d -t0
    • helpme
      It opens fluent, but when i try to import a .msh file it gives the following error
      Reading "| utility fl42seg CUsers/Ryan Pereira/Desktop/nh.msh"...
      Building...
      mesh
      Error: Null Domain Pointer
      Error: Null Domain Pointern
      Error Object: #f
    • tsiriaks
      This command
      is equivalent to you setting
      Processing Options : Parallel
      Processes : 0
      in the Fluent Launcher, which I stated in the thread above. The issue that prevents you from using multiple cores (MPI) is as described in that thread as well. You have to find on your machine what is blocking those processes , e.g., anti-virus , Firewall, VPN, etc.
      The issue about importing mesh is a different one. It's best to get help about this issue from Physics Simulation  ->  Fluid Dynamics  section.
Viewing 5 reply threads
