Ansys Products
Ansys Products
Ansys 19.2 Silent Uninstall
    • jimguffw
      I am working on a script to silently uninstall Ansys 19.2. With our install and uninstall scripts we prefer to have no user interaction. When I use the arguments given in the Registry Editor uninstall string, a progress bar appears; we do not want this to show up. Are there any arguments that would make it uninstall totally silently? Here are the arguments we have already used: "-runfromtemp -10x0490 -removeonly", "S", "s", "-Silent", "-silent", "-uninst", "-removeonly -qn". Any information would be appreciated.
    • tsiriaks
      Hmm, you shouldn't see any progress bar if you run
      "%awp_root1##%uninstall.exe" -silent
      Can you take a screenshot of the progress bar that you see when you ran above command ?
    • jimguffw
    • tsiriaks
      Ah, I see.
      Didn't realize you were talking about AnsysEM.
      In this case, you can try
      "C:Program FilesAnsysEMAnsysEM19.4Win64Uninstallsetup.exe"  /z  suppressconfirmation /removeonly
      if you run into issue with above command try
      copy
      "C:Program FilesAnsysEMAnsysEM19.4Win64Uninstall"
      to
      "C:Program FilesAnsysEMUninstallANSYS Electromagnetics Suite 19.4 (64-bit)"
      then run:
      "C:Program FilesAnsysEMUninstallANSYS Electromagnetics Suite 19.4 (64-bit)setup.exe" /z suppressconfirmation /removeonly.
    • jimguffw
      We just tried out both options neither of them worked. Do you have any other suggestions? I should also note that we build the packages on an VM.
    • George Karnos
      Please try the following command:
      "C:Program FilesAnsysEMAnsysEM19.4Win64Uninstallsetup.exe" /runfromtemp /z suppressconfirmation /removeonly
      (Change to the correct version directory)
      Thank You,
      Geo
    • jimguffw
      I gave it a shot. The progress bar still popped up. Do you have any other suggestions? For our uninstallers we do not want any progress bar to show up.
    • tsiriaks
      You may have to record a response file of uninstallation on one machine using
      "C:Program FilesAnsysEMAnsysEM19.4Win64Uninstallsetup.exe" -r -f1""
      then, use that response file on any other machines for silent uninstall using the following command (note you will have to adjust installed path in the response file if they are not the same on other machines)
      setup.exe -s -f1"" -f2""
      Notice that there is no space between f1 and its corresponding file path. The same for f2.
      Thanks,
      Win
    • jimguffw
      Sorry for the delay. I tried the above suggestion and it worked. Thank you for all your help.
    • tsiriaks
      That's great ! Glad it works for you.
      Could you mark this thread as 'resolved' ('Is Solution') , so we know it's been addressed ?
      Thanks,
      Win
Viewing 9 reply threads
