October 27, 2018 at 1:30 pm
October 28, 2018 at 11:11 am
October 29, 2018 at 11:13 pm
tsiriaks
Ansys EmployeeHi invalidz,
I'm guessing your username or computer name might have some non-english language or some special character
Could you post the screenshot of the output of the 'set' command (without quote ' ') from the CMD Prompt ?
Thank you,
Win
October 30, 2018 at 8:24 am
October 30, 2018 at 9:25 am
seeta gunti
Ansys EmployeeHi
Looks like installation issue. Can you uninstall and install again and check whether you are able to open workbench. Make sure you give the right license file.
Seeta
October 30, 2018 at 11:55 am
dingkang_liu
SubscriberHi Seeta,
I have uninstall and install again.but it still has the same problem.
Thank you
October 30, 2018 at 4:18 pm
tsiriaks
Ansys EmployeeHi dingkang_liu ,
Can you try with other username that's not 'Administrator' ?
Also, try setting the default language of your computer to be English.
https://www.windowscentral.com/how-properly-change-system-default-language-windows-10
If these don't help, please follow this step
in the Windows search (from taskbar), type
%temp%.ansys
then look for the file that says 'demo.
.log'
Open this file up and scroll to the bottom of the file and post the screenshots of it. Essentially I would like to see the screenshot similar to what will4074 is posting here https://forum.ansys.com/forums/topic/ansys-workbench-18-2-4/
Thank you,
Win
October 31, 2018 at 9:14 am
dingkang_liu
SubscriberHi tsiriaks,
After I change the language to English,this problem is solved.
Thank you very much.
liu
October 31, 2018 at 5:56 pm
tsiriaks
Ansys EmployeeHi liu,
That's great !
Thank you for the update.
Win
November 3, 2018 at 2:46 pm
- Workbench error
- Workbench not opening
- License Error
2524
2066
1285
1096
459
