November 2, 2018 at 12:10 pm
deepakpushpad
Subscriberhello dears
i am using msi nvidia gt 710 2gb graphics card, but i am facing problems with space claim that "Geometry editor was closed abnormally'
it is working on stand alone mode but graphics problem is there (pl see attached images).
apart from it i have checked using dxdiag that direct3d is enabled
November 2, 2018 at 12:11 pm
November 3, 2018 at 7:37 pm
SubscriberTry this. Another user had this problem.
ANSYS has a list of graphics cards that they test their software to make sure it works properly on those cards. If you want reliable operation, buy a tested graphics card. Some of them are for laptops.
November 6, 2018 at 8:27 am
Keyur Kanade
Ansys EmployeeIf you issue is resolved, can you please mark this as 'Is Solution'
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
