Ansys 19, Strain rate effect on material properties
    • suleyman41
      Hello, I want to learn that how I add strain rate effect material properties.
      I have a stress-strain curve for multi-linear hardening. but not only one strain rate, but also I have a different stress-strain rate.
      how I define this style of material properties in Ansys?
    • jj77
      For strain rate sensitive material (e.g., steel), often the Johnson Cook (JC) model is used, in explicit dynamics - see the help manual on that.
      (Not sure how to use/convert your data into the JC parameters needed in Ansys - perhaps if you look on the internet or if someone else knows)
      Also this is of help:
      https://caeai.com/blog/importance-including-strain-rate-effects-explicit-dynamics-material-models
    • suleyman41
      Thank you for your answer.
      I have a stress-strain graph. accept melting temperature and ambient temperature constant. i've stress-strain curve and  strain rate, how can I determine the johnson-cook parameters using the data I have.,
      I have this one, and also strain rate, may i determine johnson cook parameters. temperatures are constant value.
