July 24, 2019 at 12:03 pm
michaelmaalouly
SubscriberHello,
I am having trouble with ANSYS 2019 R2 FLUENT.
While simulating, fluent is crashing. The event logger notes the following error:
Faulting application name: cx1940.exe, version: 0.0.0.0, time stamp: 0x5cb5e2bc
Faulting module name: dx11_2300_x64.hdi, version: 23.0.0.0, time stamp: 0x5a3b8363
Exception code: 0xc0000005
Fault offset: 0x000000000000d923
Faulting process id: 0x2f5c
Faulting application start time: 0x01d5407538359826
Faulting application path: C:PROGRA~1ANSYSI~1v194fluentfluent19.4.0cortexwin64cx1940.exe
Faulting module path: C:PROGRA~1ANSYSI~1v194fluentntbinwin64dx11_2300_x64.hdi
Report Id: 73317364-c0a4-4ff2-b666-65a9f9c6b7fd
Is there any fix for this problem?
Thank you.
July 24, 2019 at 3:33 pm
Ansys EmployeeIf the code is running are there any errors in the solver?
July 24, 2019 at 4:19 pm
michaelmaalouly
SubscriberNo errors appear in the solver while the code is running.
I run my simulations overnight, and it has happened twice now: I start the simulation, come the next day to check on it and I find that FLUENT crashed and that the program closed.
July 24, 2019 at 4:44 pm
tsiriaks
Ansys EmployeeAre you using ANSYS Student version ?
What graphics card do you have on the machine ?
Open CMD Prompt, and issue the following command
"C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_util" -statli 2325@localhost > C:Tempstat.log
wait for a minute, then open C:Tempstat.log with notepad (or any text editor tool) and copy the entire content of it and post it here
July 25, 2019 at 8:31 am
michaelmaalouly
SubscriberI am using a full academic ANSYS license, and the GPU mounted on the machine is NVIDIA Quadro P1000.
The content requested is posted below: (hostname and IP are removed for security reasons)
Attempting to connect to ansysli_server running on 2325@...
Connection Established. Querying for additional information...
ANSYSLI_PORT = 2325
Hostname =
IP =
Process Id = 1896
Full Version = 1.9.8 (20190402) for winx64. Updated at ANSYS Release 2019 R2.
Startup = NORMAL STARTUP 2019/07/24 16:53:27
Active Clients = 22
Max Clients = 22
Total Clients = 1118
WB Usage Tracking = ON
DP Reserve Support = ON
Service Status = No problems found
Service Status Message : The ANSYS LM service and the Licensing Interconnect are using the same exe.
Monitor Status : Monitor Running
Monitor Version : ANSYS Licensing Interconnect version 1.9.7 (20190402) for winx64. Updated at ANSYS Release 2019 R2.
Licenses Cached for server:
FEATURE COUNT VERSION EXPIRATION
a_spaceclaim_catv5 275 2019.1014 permanent
a_spaceclaim_dirmod 275 2019.1014 permanent
aa_ds 250 2019.1014 permanent
aa_mcad 50 2014.1014 permanent
aa_mcad 275 2019.1014 permanent
aa_r 25 2019.1014 permanent
aa_r_hpc 10 2014.1014 permanent
aa_r_hpc 128 2019.0914 permanent
aa_r_hpc 128 2019.1014 permanent
aa_t_a 250 2019.1014 permanent
aa_t_cfd 50 2014.1014 permanent
afsp_gui 50 2014.1014 permanent
afsp_gui 275 2019.1014 permanent
afsp_optigrid 50 2014.1014 permanent
afsp_optigrid 275 2019.1014 permanent
afsp_viewmerical 50 2014.1014 permanent
afsp_viewmerical 275 2019.1014 permanent
aice_mesher 275 2019.1014 permanent
aice_opt 275 2019.1014 permanent
aice_pak 275 2019.1014 permanent
aice_solv 275 2019.1014 permanent
aiiges 275 2019.1014 permanent
aim_mp1 50 2014.1014 permanent
aim_mp1 275 2019.1014 permanent
al4allegro 275 2019.1014 permanent
al4ansoft 275 2019.1014 permanent
al4apd 275 2019.1014 permanent
al4boardstation 275 2019.1014 permanent
al4cadvance 275 2019.1014 permanent
al4cds 275 2019.1014 permanent
al4expedition 275 2019.1014 permanent
al4first 275 2019.1014 permanent
al4gem 275 2019.1014 permanent
al4generic 275 2019.1014 permanent
al4odb++ 275 2019.1014 permanent
al4powerpcb 275 2019.1014 permanent
al4virtuoso 275 2019.1014 permanent
al4zuken 275 2019.1014 permanent
ansoft_distrib_engine 2264 2019.1014 permanent
designer_hspice 275 2019.1014 permanent
electronics2d_gui 275 2019.1014 permanent
electronics3d_gui 275 2019.1014 permanent
electronics_desktop 275 2019.1014 permanent
electronicsckt_gui 275 2019.1014 permanent
emit_legacy_gui 275 2019.1014 permanent
emit_solve 275 2019.1014 permanent
ensemble_25_sim 275 2019.1014 permanent
filter_synthesis 275 2019.1014 permanent
hfss_solve 275 2019.1014 permanent
hfss_transient_solve 275 2019.1014 permanent
hfsshpc 4528 2019.1014 permanent
hfsssbr_solve 275 2019.1014 permanent
m2dfs_qs_solve 275 2019.1014 permanent
m2dfs_solve 275 2019.1014 permanent
m3dfs_qs_solve 275 2019.1014 permanent
m3dfs_solve 275 2019.1014 permanent
maxwlspc 275 2019.1014 permanent
nexxim_ami 275 2019.1014 permanent
nexxim_dc 275 2019.1014 permanent
nexxim_eye 275 2019.1014 permanent
nexxim_hb 275 2019.1014 permanent
nexxim_netlist 275 2019.1014 permanent
nexxim_osc 275 2019.1014 permanent
nexxim_tran 275 2019.1014 permanent
nexxim_tvnoise 275 2019.1014 permanent
optimetrics 275 2019.1014 permanent
pemag 275 2019.1014 permanent
pexprt 275 2019.1014 permanent
rmxprt_bcm 275 2019.1014 permanent
rmxprt_ecm 275 2019.1014 permanent
rmxprt_im 275 2019.1014 permanent
rmxprt_sym 275 2019.1014 permanent
savant_legacy_gui 275 2019.1014 permanent
si2d_solve 275 2019.1014 permanent
si3d_solve 275 2019.1014 permanent
simplorer_advanced 275 2019.1014 permanent
simplorer_control 275 2019.1014 permanent
simplorer_cprogrinterface 275 2019.1014 permanent
simplorer_gui 275 2019.1014 permanent
simplorer_libsmps 275 2019.1014 permanent
simplorer_model_export 275 2019.1014 permanent
simplorer_modelica 275 2019.1014 permanent
simplorer_sim 275 2019.1014 permanent
simplorer_sim_entry 275 2019.1014 permanent
simplorer_vhdlams 275 2019.1014 permanent
siwave_gui 275 2019.1014 permanent
siwave_level1 275 2019.1014 permanent
siwave_level2 275 2019.1014 permanent
siwave_level3 275 2019.1014 permanent
symphony_dt_sim 275 2019.1014 permanent
symphony_fd_sim 275 2019.1014 permanent
xlate_catia4 275 2019.1014 permanent
xlate_catia5 275 2019.1014 permanent
xlate_iges 275 2019.1014 permanent
xlate_inventor 275 2019.1014 permanent
xlate_parasolid 275 2019.1014 permanent
xlate_proe 275 2019.1014 permanent
xlate_solidworks 275 2019.1014 permanent
xlate_step 275 2019.1014 permanent
xlate_unigraphics 275 2019.1014 permanent
July 25, 2019 at 5:55 pm
tsiriaks
Ansys EmployeeHi michaelmaalouly,
Thank you for the info.
Please try the following in this order
-Update the driver of your NVIDIA Quadro P1000 to the latest available according to Nvidia website (https://www.nvidia.com/Download/index.aspx?lang=en-us)
-Right click on the desktop then launch Nvidia Control Panel >> Manage 3D settings >> set Preferred graphics processor to be "High-performance NVIDIA processor”.
-Fluent Launcher -> Show More Options -> Environment , then add this
LAUNCHER_FLUENT_OPTIONS=-driver opengl
Thanks,
Win
August 6, 2019 at 10:17 am
michaelmaalouly
SubscriberThank you for your help Win.
It seems like updating the GPU driver solved the problem.
August 6, 2019 at 4:18 pm
tsiriaks
Ansys EmployeeThat's great to hear !
Thank you for the update.
Win
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2706
2138
1355
1144
462
