Ansys Products
Ansys Products
Ansys 2020R2 n-Code modules
    • AndreCorrea
      I have access to ANSYS 2020 R2 at my company.
      I need n-code to generate PSD for test synthesis from vibration profiles, so I tried to add it to ANSYS as an ACT through ANSYS's web store. But it only enabled the module showed on the image attached below. Since this module is embedded to mechanical I can't perform my task independently as it is geometry/mesh dependent.
    • ANSYS_MMadore
      As you are a commercial customer you can access the Ansys Customer Portal and have access to direct Technical Support. If you don't already have an account you can register at support.ansys.com.
