March 28, 2021 at 5:50 am
Nawaf_Ar
SubscriberHi, I downloaded, and installed v211 ANSYS Student version (the first, and only time I installed ANSYS on this PC) in Feb 2021, and started it once to make sure it was working, and it worked fine.
I shut it down, and now almost two months later, my toolbox vanished when I opened it again. I never used it except for the first time to check everything was working.
March 28, 2021 at 6:18 amNawaf_Ar
SubscriberHi, to anyone experiencing this issue.nI've managed to solve it for now (hopefully doesn't happen again), by doing a complete uninstall.nGo to your install directory, unconfigure everything, uninstall ansys, delete the ansys file in Appdata\Roaming reset your PC, delete the installation file, and redownload it, and install all over, should work now. No clue why it didn't before, also I've tried doing any of these steps on their own, and it didn't work. Only by doing everything did it work.nMarch 29, 2021 at 4:10 pmRob
Ansys EmployeenThe original licence key was mis-coded to give you about a month of use and not the 12 it should have. So, in this case the uninstall & re-download fixed it. You don't normally have to do that. nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2614
2090
1321
1108
459
