January 29, 2022 at 4:50 pm
KHarkin
SubscriberAfter installing ANSYS student the error log quoting "Graphics driver verification and setup error" is given and I cannot start the application (full error log below). Any ideas on how to fix this, the graphics card I'm using is the AMD Radeon Vega 8 Graphics Card for context.
January 31, 2022 at 8:22 amRuturaj Gavali
Ansys EmployeeHey @KHarkin !
The most common reason for graphics issues is because you have an older or unsupported graphics card/driver installed on your system.
Could you please check whether you have ANSYS supported graphics card (NVDIA or AMD) in your system.
In the RUN command type: dxdiag , go to display and check the graphics card.
Please review this document for ANSYS supported graphics cards: Graphics Cards Tested (ansys.com)
Could you also try downloading and installing the latest driver for your graphics card.
Also, this post might be helpful: installation problem (Error executing configuration script) — Ansys Learning Forum
Thanks!
For more information, check out the following links:
Ansys Help
Ansys Learning Forum (Rules & Guidelines)December 26, 2022 at 11:47 amPalani Ganesan
SubscriberHi Ansys Team,
I am also facing the same problem, my system display adapter is NVIDIA GeForce GTX 1650. Can you please confirm, is there is any option for Ansys to support for this adapter.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5290
3311
2469
