Ansys Free Student Software
ANSYS 2022 R1 – No suitable license was available to be checked out
    • ejg
      I have an issue with launching the software. I am trying to launch the Workbench, the loading window apears and then closes. I am also trying to launch the Turbo Grid mesher and an error message appears "No suitable license was available to be checked out". Does anyont have any advise on how to solve my issue ?
      Thanks in advance,
    • George Karnos
      One recommendation would be to rename the following directory
      %APPDATA%\Ansys to Ansys.old
      Try to run.
      If that doesnt help, uninstall, rename c:\Program files\ANSYS Inc to Ansys_old
      Reinstall from a fresh download making sure you right click on setup.exe and choose" more-> run as administrator
      If that does not help:
      If you click on view in the above error, what does it show?
      Also, under %TEMP%\ there should be a directory: WorkbenchLogs, do they show any errors?
      One more item to look at:
      under %TEMP%\.ansys, there should be licdebug.out files. They will show licensing erors.
      Can you post the error contents of the file as we are not permitted to open files.
