January 31, 2022 at 1:15 am
tofuu88
SubscriberHello, I have an observation: When using Remote Solve Manager to send jobs to a local staging directory for solving, the license is not found in Ansys 2021R2 and Ansys 2022R1. However, in Ansys 2021R1, this works. The error message indicates max demo license is reached even though there's nothing else taking up the license.
Literally the same thing works in 2021R1 but does not work in 2022R1 or 2021R2. Can someone from Ansys please help me understand if this is intended?
Again, I want to know if this is intended to no longer work after 2021R1?
February 8, 2022 at 9:19 pmANSYS_MMadore
Ansys EmployeeDoing this should generate some files in the %TEMP%\.ansys directory with names like licdebug.MECH.212.out or licdebug.ANSYS.212.out. Can you please share the content of these logs? You may want to close all Ansys applications, then delete the contents of this directory and then recreate the issue so the logs will be relevant just to this specific issue.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3648
2534
1745
1226
578
