December 13, 2022 at 2:42 pm
Sean Albano
SubscriberHello,
Been having issues getting specifically ANSYS 2022R2 to license certain modules within the program from flexnet. Did some tests and it seems to specifically having issues communicating via TCP to pull the licenses. In past versions the program would give popups to accept firewall exceptions so everything would work just fine, but with 2022R2 specifically, those prompts are gone and even with allowing the ports and everything to communicate through our firewall, it still wont license some modules.
The quesiton I really want to ask is has anything changed with how 2022R2 pulls it's license compared to past versions? In the licensing program, when I test the connection it's able to pull a license just fine, and some modules like Fluent can license just fine, but modules like Workbench just hang until they fail to pull the license.
Any tips would be appreciated because we're pretty stumped at this point.
December 19, 2022 at 4:34 pm
George Karnos
Ansys EmployeePlease check the firewalls to ensure access to the licensing port 1056 as well as 1055 and 2325.You can set ansyslmd to a static port 1056 by adding it in the license file on the VENDOR line.(c:\Program files\Ansys Inc\shared files\licensing\license_files\ansyslmd.lic)(/ansys_inc/shared_files/licensing/license_files/ansyslmd.lic)For example:VENDOR ansyslmd PORT=1056After doing so, restart the license manager.Please test to make sure the client can ping the server by the hostname in the license file.Please make sure they can telnet to the server on each of the licensing ports.-
December 20, 2022 at 3:34 pm
Sean Albano
SubscriberHi George,
I went into the directory you listed, and the license file is actually one directory up in the 'licensing' folder instead of license_files folder. That file also only has 2 lines in it: SERVER= and ANSYSLI_SERVERS=
After each line is port@licenseurl and that's it.
For the VENDOR ansyslmd PORT=1056 line you put, would that be in this format instead: VENDOR_ansyslmd_PORT=1056 if I add it to the license file?
Thank you for the input so far though.
December 20, 2022 at 3:59 pm
George Karnos
Ansys EmployeeFrom your description, it sunds like you are working on a client machine.
And, are editing the ansyslmd.ini file.
Apologies, my instructions should be performed on the License Server Machine.
- Workbench error
- Workbench not opening
- License Error
2508
2064
1277
1088
456
