September 27, 2019 at 11:17 am
moad123uk
SubscriberHello,
I was able to connect matlab with ansys using the toolbox provided.
my problem is that i don't know how to transfer data from matlab to ansys. for example if I create a variable on matlab say:
a = 22;
This line doesn't work:
mapdlResult=char(iCoMapdlUnit.executeCommandToString('aas_parameter_test= a'))
is there a certain way of doing it? I cant seem to figure it out
November 25, 2019 at 2:49 am
JTWD
Subscriberhello, I'm sure you hope your find a solution for your problem.
I'm not sure but when you input mapdlResult=char(iCoMapdlUnit.executeCommandToString('aas_parameter_test= a'))
The char will make it as just 'a', isn't it ?
Good luck ! -
March 28, 2023 at 4:24 am
Xia Jinhao
SubscriberHello,
Have you solved this problem? I have also encountered this problem.
Could you tell me how to solve this problem?
Thank you.
March 28, 2023 at 4:25 am
Xia Jinhao
SubscriberHello, Have you solved this problem? I have also encountered this problem. Could you tell me how to solve this problem? Thank you.
4502
2957
1449
1322
