December 9, 2020 at 5:52 am
mstricks
SubscriberDear,
I have a question related to Ansys ACP, What is the need to define stack up and sub-laminate in ACP pre-post, is it related to meso and micro modeling of the composite plate.
And what is the actual purpose of sub-laminate and stack-up when already we define ply as modeling of ply and fabric in a fabric domain?
Thank you in advance for any kind of clarification.
Regards
December 16, 2020 at 12:14 am
Sean Harvey
Ansys EmployeeHello,nSo I think what you want is what is shown below. Where the entities will be the elements that make up the composite tube. You change the Sensor type to Sensor by area. My example is for a simple 1x2 plate. Can you please try this and let us know? There are other options but hope this helps.nnThank younSeannn
- The topic ‘ANSYS ACP’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8832
4658
3159
1688
1482
