Ansys Products
Ansys Products
Ansys ACP solid model failure
    • peter.greaves
      I'm trying to make a solid model of a wind turbine blade. If I build the model and select anything which is at or more detailed than 'Modelling Ply Wise' for the extrusion method then the model generates OK. However, if I try to use a detail level which is appropriate for my model (Monolithic, or at most 'Material Wise') then I get the following error:
      Any ideas how I can fix this? I really need to reduce the complexity, but I also really need to create a solid model!
    • Ashish Khemka
      Hi Peter,
      Please see if the following post helps you:
      Orientation of the layer application for curved surfaces in acp (pre) (ansys.com)
      Ashish Khemka
