August 28, 2019 at 12:29 am
sohailmohammed777
SubscriberWhat is the kind of heat source is being used in the Additive Wizard can anyone let me know?
August 28, 2019 at 12:59 am
Sandeep Medikonda
Ansys Employee -
August 28, 2019 at 4:09 pm
sohailmohammed777
SubscriberYes Sir. That's true but may I know the kind of laser heat source it is assuming such as(Volumetric heat source approach or Gaussian Elliptic) ?? And also may I know how to differentiate whether the simulation is PFB or DED ?
August 28, 2019 at 4:18 pm
Sandeep Medikonda
Ansys EmployeeThe laser is not simulated...the whole layer (which uses the super layer element approach) is brought to melting temperature. Please see the methodology section in the help.
PBF is the default analysis type. DED would require a command snippet.
2120
1349
1136
461
