November 9, 2020 at 5:18 pm
aljarah.ahmad94
SubscriberHello
I am using Ansys Aim to perform magnetics analysis.
Is it possible to know what element type the software is using when it creates the default mesh. Moreover, can I change this element type ?
Many Thanks
November 10, 2020 at 10:04 am
Subashni Ravichandran
Forum ModeratorHello Ahmad
Have you tried checking the Transcript for element type?
Let me check with my team on this and get back to you.
November 10, 2020 at 10:27 am
aljarah.ahmad94
SubscriberSubashni
Dear Subashni
Thank you for your reply.
The choices I found related to the mesh settings in Ansys Aim magnetics solver are very limited.
I would really appreciate it if you can check with your team for help.
January 8, 2021 at 4:53 am
I checked with my team but I don't see any way we can change the element type in AIM.
- The topic ‘Ansys Aim magnetics analysis’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
