Ansys Free Student Software
ANSYS Aim Student Freezes When Opening Model Editor
    • Paul_R
      I'm new to ANSYS & recently download ANSYS Aim Student 19.2 as I will be using it for my final year project in university.  Unfortunately when I attempt to design a new geometry through the Model Editor it freezes while trying to open it.  When I first downloaded ANSYS it had no problem opening & running Model Editor so I don't think its a computer problem.  I've even gone as far as completely uninstalling & deleting all ANSYS files then re-downloading the program yet the same problem still occurs. I am using a LENOVO ideapad 330s & have attached a screenshot of the frozen screen.
      Thanks in advance.
    • tsiriaks
      Hi Paul_R,
      Please try resetting configurations
      Rename folder v192 in this directory
      %AppData%Ansys     (please copy and paste this in the Windows Explorer address bar)
      to anything else (e.g., v192.old)
      If that doesn't help, launch CMD Prompt, then type dxdiag , then “enter”
      The DirectX Diagnostic Tool pop-up window should appear.
      Click on, "Save all information".
      Click on, "Save"
      then copy and paste the content of the saved file and post it on this thread.
      Thank you,
      Win
    • Paul_R
      I ended up using Parallels Desktop to run my Windows on my Mac hoping it would solve the problem but the same thing keeps happening.  With the Mac however it actually shows the error message(which I have attached below) instead of just completely freezing from the as soon as I attempt to open Model Designer.  I also attempted to rename the folder on both computers however it didn't change anything so have pasted the DirectX Diagnostic content below.
      System Information
            Time of this report: 9/20/2018, 10:452
                   Machine name: LAPTOP-LIEETD7S
                     Machine Id: {B87C855C-4720-4615-816B-C2A73367522A}
               Operating System: Windows 10 Home 64-bit (10.0, Build 16299) (16299.rs3_release_svc.180808-1748)
                       Language: English (Regional Setting: English)
            System Manufacturer: Parallels Software International Inc.
                   System Model: Parallels Virtual Platform
                           BIOS: 14.0.1 (45154)
                      Processor: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz (2 CPUs), ~2.2GHz
                         Memory: 2048MB RAM
            Available OS Memory: 2026MB RAM
                      Page File: 2066MB used, 1111MB available
                    Windows Dir: C:Windows
                DirectX Version: DirectX 12
            DX Setup Parameters: Not found
               User DPI Setting: 192 DPI (200 percent)
             System DPI Setting: 96 DPI (100 percent)
                DWM DPI Scaling: Enabled
                       Miracast: Not Available
      Microsoft Graphics Hybrid: Not Supported
                 DxDiag Version: 10.00.16299.0015 64bit Unicode
      DxDiag Notes
            Display Tab 1: No problems found.
              Sound Tab 1: No problems found.
                Input Tab: No problems found.
      DirectX Debug Levels
      Direct3D:    0/4 (retail)
      DirectDraw:  0/4 (retail)
      DirectInput: 0/5 (retail)
      DirectMusic: 0/5 (retail)
      DirectPlay:  0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow:  0/6 (retail)
      Display Devices
                 Card name: Parallels Display Adapter (WDDM)
                 Chip type: Virtual Adapter
                  DAC type: Integrated RAMDAC
               Device Type: Full Device
                Device Key: EnumPCIVEN_1AB8&DEV_4005&SUBSYS_04001AB8&REV_00
             Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
       Device Problem Code: No Problem
       Driver Problem Code: Unknown
            Display Memory: 1012 MB
          Dedicated Memory: 0 MB
             Shared Memory: 1012 MB
              Current Mode: 2880 x 1800 (32 bit) (60Hz)
               HDR Support: Not Supported
          Display Topology: Internal
       Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
           Color Primaries: Red(0.640148,0.330578), Green(0.300305,0.600109), Blue(0.150891,0.060070), White Point(0.313000,0.329602)
         Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
              Monitor Name: Generic Non-PnP Monitor
             Monitor Model: Parallels Vu
                Monitor Id: PRL5000
               Native Mode: 2880 x 1800(p) (59.998Hz)
               Output Type: HD15
      Monitor Advanced Color Capabilities: None
      Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
               Driver Name: prl_umdd.dll,prl_umdd10.dll,prl_umdd10.dll
       Driver File Version: 8.15.0010.45154 (English)
            Driver Version: 14.0.45154.0
               DDI Version: 10.1
            Feature Levels: 10_1,10_0,9_3,9_2,9_1
              Driver Model: WDDM 1.1
       Graphics Preemption: DMA
        Compute Preemption: DMA
                  Miracast: Not Supported
       Hybrid Graphics GPU: Not Applicable
            Power P-states: Not Applicable
         Driver Attributes: Beta Debug
          Driver Date/Size: 07/09/2018 1:00:00 AM, 167856 bytes
               WHQL Logo'd: Yes
           WHQL Date Stamp: Unknown
         Device Identifier: {D7B71458-0345-11CF-6AC9-0A24A0C2C535}
                 Vendor ID: 0x1AB8
                 Device ID: 0x4005
                 SubSys ID: 0x04001AB8
               Revision ID: 0x0000
        Driver Strong Name: oem51.inf:e4bc28de2924396bDInstall64_6.NTamd64:14.0.45154.0CIVEN_1AB8&DEV_4005&SUBSYS_04001AB8
            Rank Of Driver: 00E00001
               Video Accel:
               DXVA2 Modes: Unknown
         Deinterlace Caps: {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5BDB4C2A-B67A-495F-B275-6DFC87C55F88}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
              D3D9 Overlay: Not Supported
                   DXVA-HD: Not Supported
              DDraw Status: Enabled
                D3D Status: Enabled
                AGP Status: Enabled
             MPO MaxPlanes: 1
                  MPO Caps: Not Supported
               MPO Stretch: Not Supported
           MPO Media Hints: Not Supported
               MPO Formats: Not Supported
          PanelFitter Caps: Not Supported
       PanelFitter Stretch: Not Supported
      Sound Devices
                  Description: Speakers (Parallels Audio Controller)
       Default Sound Playback: Yes
       Default Voice Playback: Yes
                  Hardware ID: PCIVEN_1022&DEV_746D&SUBSYS_04001AB8&REV_00
              Manufacturer ID: 1
                   Product ID: 100
                         Type: WDM
                  Driver Name: prl_sound.sys
               Driver Version: 14.00.0001.45154 (English)
                  WHQL Logo'd: Yes
                Date and Size: 07/09/2018 12:00:00 AM, 64944 bytes
                  Other Files:
              Driver Provider: Parallels
               HW Accel Level: Basic
                    Cap Flags: 0xF1F
          Min/Max Sample Rate: 100, 200000
      Static/Strm HW Mix Bufs: 1, 0
       Static/Strm HW 3D Bufs: 0, 0
                    HW Memory: 0
             Voice Management: No
       EAX(tm) 2.0 Listen/Src: No, No
         I3DL2(tm) Listen/Src: No, No
      Sensaura(tm) ZoomFX(tm): No
      Sound Capture Devices
                  Description: Microphone (Parallels Audio Controller)
        Default Sound Capture: Yes
        Default Voice Capture: Yes
                Date and Size: 9/7/2018 19:46:54, 64944 bytes
                    Cap Flags: 0x1
                 Format Flags: 0xFFFFF
      Video Capture Devices
      Number of Devices: 1
                 FriendlyName: FaceTime HD Camera
                 SymbolicLink: \?usb#vid_203a&pid_fff9&mi_00#6&f90391c&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}global
                 Manufacturer: Microsoft
                   HardwareID: USBVID_203A&PID_FFF9&REV_0100&MI_00,USBVID_203A&PID_FFF9&MI_00
                   DriverDesc: USB Video Device
               DriverProvider: Microsoft
                DriverVersion: 10.0.16299.15
            DriverDateEnglish: 6/21/2006 00:00:00
          DriverDateLocalized: 21/06/2006 12:00:00 AM
                      Service: usbvideo
                        Class: Camera
                DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
                  ContainerId: {6D22F984-CB37-53B1-8703-2F4433BE6E5E}
                  ProblemCode: No Problem
        BusReportedDeviceDesc: FaceTime HD Camera
                       Parent: USBVID_203A&PID_FFF9CC25072K2KJF6VVDE
            DriverProblemDesc: n/a
                 UpperFilters: n/a
                 LowerFilters: n/a
                        Stack: FileSystemaswSnx,Driverksthunk,Driverusbvideo,Driverusbccgp
            ContainerCategory: n/a
      DirectInput Devices
            Device Name: Mouse
               Attached: 1
          Controller ID: n/a
      Vendor/Product ID: n/a
              FF Driver: n/a
            Device Name: Keyboard
               Attached: 1
          Controller ID: n/a
              FF Driver: n/a
            Device Name: Pen Interface
               Attached: 1
          Controller ID: 0x0
      Vendor/Product ID: 0x203A, 0xFFFC
              FF Driver: n/a
      Poll w/ Interrupt: No
      USB Devices
      + USB Root Hub
      | Vendor/Product ID: 0x8086, 0x2658
      | Matching Device ID: USBROOT_HUB
      | Service: usbhub
      | Driver: usbhub.sys, 9/29/2017 14:41:08, 513944 bytes
      | Driver: usbd.sys, 9/29/2017 14:41:08, 32152 bytes
      +-+ USB Composite Device
      | | Matching Device ID: USBCOMPOSITE
      | | Service: usbccgp
      | | Driver: usbccgp.sys, 9/29/2017 14:41:08, 168856 bytes
      | +-+ USB Input Device
      | | | Matching Device ID: USBClass_03
      | | | Service: HidUsb
      | | | Driver: hidusb.sys, 9/29/2017 14:41:08, 40960 bytes
      | | | Driver: hidclass.sys, 9/29/2017 14:41:08, 187392 bytes
      | | | Driver: hidparse.sys, 6/8/2018 07:05:26, 46080 bytes
      | | +-+ Parallels USB Mouse Synchronization Device
      | | | | Matching Device ID: HIDVID_203A&PID_FFFC&MI_00
      | | | | Upper Filters: prl_mouf
      | | | | Service: mouhid
      | | | | Driver: prl_mouf.sys, 9/7/2018 19:46:54, 31152 bytes
      | | | | Driver: mouhid.sys, 9/29/2017 14:41:08, 32768 bytes
      | | | | Driver: mouclass.sys, 9/29/2017 14:41:08, 57240 bytes
      | | | Service: HidUsb
      | | +-+ HID-compliant mouse
      | | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
      | | | | Service: mouhid
      +-+ Generic USB Hub
      | | Vendor/Product ID: 0x203A, 0xFFFE
      | | Matching Device ID: USBClass_09
      | | Service: usbhub
      | | | Vendor/Product ID: 0x203A, 0xFFFB
      | | | Matching Device ID: USBClass_03&SubClass_01
      | | | Service: HidUsb
      | | +-+ HID Keyboard Device
      | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
      | | | | Service: kbdhid
      | | | | Driver: kbdhid.sys, 9/29/2017 14:41:08, 40448 bytes
      | | | | Driver: kbdclass.sys, 9/29/2017 14:41:08, 63384 bytes
      Gameport Devices
      PS/2 Devices
      + Standard PS/2 Keyboard
      | Matching Device ID: *PNP0303
      | Service: i8042prt
      | Driver: i8042prt.sys, 9/29/2017 14:41:08, 105984 bytes
      + Parallels Mouse Synchronization Device
      | Matching Device ID: ACPIPNP0F03
      | Service: i8042prt
      Disk & DVD/CD-ROM Drives
            Drive: C:
       Free Space: 863.7 GB
      Total Space: 927.0 GB
      File System: NTFS
            Model: Windows 10
            Drive: D:
            Model: Windows 10
            Drive: E:
            Model:  Virtual DVD-ROM ATA Device
           Driver: c:windowssystem32driverscdrom.sys, 10.00.16299.0579 (English), 7/18/2018 02:513, 159744 bytes
      System Devices
           Name: CPU to IO Controller
      Device ID: PCIVEN_8086&DEV_29A0&SUBSYS_04001AB8&REV_023&11583659&1&00
         Driver: n/a
           Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
      Device ID: PCIVEN_8086&DEV_2658&SUBSYS_04001AB8&REV_023&11583659&1&E8
         Driver: C:Windowssystem32driversusbuhci.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:08, 35328 bytes
         Driver: C:Windowssystem32driversusbport.sys, 10.00.16299.0522 (English), 6/13/2018 235:44, 453024 bytes
         Driver: C:Windowssystem32driversusbhub.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:08, 513944 bytes
      Device ID: PCIVEN_8086&DEV_244E&SUBSYS_00000000&REV_F23&11583659&1&F0
         Driver: C:Windowssystem32DRIVERSpci.sys, 10.00.16299.0637 (English), 8/9/2018 06:48:43, 362936 bytes
           Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
      Device ID: PCIVEN_8086&DEV_265C&SUBSYS_04001AB8&REV_023&11583659&1&EF
         Driver: C:Windowssystem32driversusbehci.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:08, 95640 bytes
           Name: Parallels Memory Controller
      Device ID: PCIVEN_1AB8&DEV_4006&SUBSYS_40061AB8&REV_003&11583659&1&70
         Driver: C:Windowssystem32DRIVERSprl_memdev.sys, 9/7/2018 19:46:54, 29616 bytes
           Name: Standard SATA AHCI Controller
      Device ID: PCIVEN_8086&DEV_2821&SUBSYS_00000000&REV_023&11583659&1&FA
         Driver: C:Windowssystem32DRIVERSstorahci.sys, 10.00.16299.0461 (English), 5/12/2018 00:09:10, 149400 bytes
           Name: Parallels Display Adapter (WDDM)
      Device ID: PCIVEN_1AB8&DEV_4005&SUBSYS_04001AB8&REV_004&515BB0F&0&0008
         Driver: C:Windowssystem32DRIVERSprl_kmdd.sys, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 182192 bytes
         Driver: C:Windowssystem32prl_umdd.dll, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 167856 bytes
         Driver: C:Windowssystem32prl_umdd10.dll, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 172464 bytes
         Driver: C:Windowssystem32prl_gldd.dll, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 770480 bytes
         Driver: C:WindowsSysWow64prl_umdd.dll, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 145840 bytes
         Driver: C:WindowsSysWow64prl_gldd.dll, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 581552 bytes
         Driver: C:WindowsSysWow64prl_umdd10.dll, 8.15.0010.45154 (English), 9/7/2018 19:46:54, 154032 bytes
           Name: LPC Controller
      Device ID: PCIVEN_8086&DEV_2810&SUBSYS_04001AB8&REV_023&11583659&1&F8
         Driver: C:Windowssystem32DRIVERSmsisadrv.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:03, 18840 bytes
      Device ID: PCIVEN_1011&DEV_0022&SUBSYS_00000000&REV_003&11583659&1&50
           Name: Renesas USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
      Device ID: PCIVEN_1033&DEV_0194&SUBSYS_04001AB8&REV_043&11583659&1&EE
         Driver: C:Windowssystem32DRIVERSUSBXHCI.SYS, 10.00.16299.0579 (English), 7/18/2018 04:22:26, 437664 bytes
           Name: Intel(R) 82574L Gigabit Network Connection
      Device ID: PCIVEN_8086&DEV_10D3&SUBSYS_04001AB8&REV_003&11583659&1&28
         Driver: C:Windowssystem32DRIVERSe1i63x64.sys, 12.15.0022.0006 (English), 9/29/2017 14:40:59, 524800 bytes
      Device ID: PCIVEN_8086&DEV_2981&SUBSYS_00008086&REV_023&11583659&1&08
           Name: Intel(R) 82801BA Ultra ATA Storage Controller - 244B
      Device ID: PCIVEN_8086&DEV_244B&SUBSYS_04001AB8&REV_053&11583659&1&F9
         Driver: C:Windowssystem32DRIVERSintelide.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:03, 19352 bytes
         Driver: C:Windowssystem32DRIVERSpciidex.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:03, 53144 bytes
         Driver: C:Windowssystem32DRIVERSatapi.sys, 10.00.16299.0015 (English), 9/29/2017 14:41:03, 28568 bytes
         Driver: C:Windowssystem32DRIVERSataport.sys, 10.00.16299.0461 (English), 5/12/2018 00:15:23, 194456 bytes
           Name: Parallels Audio Controller
      Device ID: PCIVEN_1022&DEV_746D&SUBSYS_04001AB8&REV_003&11583659&1&FC
         Driver: C:Windowssystem32DRIVERSprl_sound.sys, 14.00.0001.45154 (English), 9/7/2018 19:46:54, 64944 bytes
         Driver: C:Windowssystem32DRIVERSdrmk.sys, 10.00.16299.0015 (English), 9/29/2017 14:40:59, 96768 bytes
         Driver: C:Windowssystem32DRIVERSportcls.sys, 10.00.16299.0015 (English), 9/29/2017 14:40:59, 379392 bytes
         Driver: C:Windowssystem32WMALFXGFXDSP.dll, 10.00.16299.0015 (English), 9/29/2017 14:40:59, 1801656 bytes
         Driver: C:Windowssystem32SysFxUI.dll, 10.00.16299.0015 (English), 9/29/2017 14:40:59, 372224 bytes
           Name: Parallels Tool Device
      Device ID: PCIVEN_1AB8&DEV_4000&SUBSYS_04001AB8&REV_003&11583659&1&18
         Driver: C:Windowssystem32DRIVERSprl_tg.sys, 14.00.0001.45154 (English), 9/7/2018 14:46:53, 39856 bytes
      DirectShow Filters
      DirectShow Filters:
      WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.16299.0015
      WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.16299.0015
      WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.16299.0015
      MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.16299.0015
      Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.16299.0015
      WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.16299.0015
      WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.16299.0015
      Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.16299.0015
      Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.16299.0015
      DV Muxer,0x00400000,0,0,qdv.dll,10.00.16299.0015
      Color Space Converter,0x00400001,1,1,quartz.dll,10.00.16299.0522
      WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.16299.0015
      AVI Splitter,0x00600000,1,1,quartz.dll,10.00.16299.0522
      VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.16299.0522
      SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.16299.0015
      Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.16299.0248
      AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015
      StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.16299.0015
      MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0522
      MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.16299.0522
      SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.16299.0522
      VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.16299.0015
      MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.16299.0015
      Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.16299.0015
      SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.16299.0015
      Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015
      Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0522
      MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.16299.0522
      DV Splitter,0x00600000,1,2,qdv.dll,10.00.16299.0015
      Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.16299.0522
      Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.16299.0015
      ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.16299.0522
      Video Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0522
      MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.16299.0015
      Line 21 Decoder,0x00600000,1,1,,
      Video Port Manager,0x00600000,2,1,quartz.dll,10.00.16299.0522
      Video Renderer,0x00400000,1,0,quartz.dll,10.00.16299.0522
      VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.16299.0015
      WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.16299.0015
      VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
      File writer,0x00200000,1,0,qcap.dll,10.00.16299.0015
      DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.16299.0015
      Overlay Mixer2,0x00200000,1,1,,
      AVI Draw,0x00600064,9,1,quartz.dll,10.00.16299.0522
      Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015
      WST Pager,0x00200000,1,1,WSTPager.ax,10.00.16299.0015
      MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015
      DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.16299.0015
      SampleGrabber,0x00200000,1,1,qedit.dll,10.00.16299.0015
      Null Renderer,0x00200000,1,0,qedit.dll,10.00.16299.0015
      MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.16299.0015
      Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.16299.0015
      StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.16299.0015
      Smart Tee,0x00200000,1,2,qcap.dll,10.00.16299.0015
      Overlay Mixer,0x00200000,0,0,,
      AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0522
      AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.16299.0522
      Wave Parser,0x00400000,1,1,quartz.dll,10.00.16299.0522
      MIDI Parser,0x00400000,1,1,quartz.dll,10.00.16299.0522
      Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.16299.0522
      File stream renderer,0x00400000,1,1,quartz.dll,10.00.16299.0522
      Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.16299.0015
      StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.16299.0015
      AVI Mux,0x00200000,1,0,qcap.dll,10.00.16299.0015
      Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.16299.0522
      File Source (Async.),0x00400000,0,1,quartz.dll,10.00.16299.0522
      File Source (URL),0x00400000,0,1,quartz.dll,10.00.16299.0522
      Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.16299.0015
      Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.16299.0248
      BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.16299.0015
      MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.16299.0522
      WDM Streaming Tee/Splitter Devices:
      Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.16299.0334
      Video Compressors:
      WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.16299.0248
      WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.16299.0015
      MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.16299.0248
      DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.16299.0015
      MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.16299.0522
      Audio Compressors:
      WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.16299.0015
      WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.16299.0015
      IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0522
      Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0522
      GSM 6.10,0x00200000,1,1,quartz.dll,10.00.16299.0522
      CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.16299.0522
      CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.16299.0522
      MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.16299.0522
      Audio Capture Sources:
      Microphone (Parallels Audio Controller),0x00200000,0,0,qcap.dll,10.00.16299.0015
      PBDA CP Filters:
      PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.16299.0192
      PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192
      PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192
      Midi Renderers:
      Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.16299.0522
      Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.16299.0522
      WDM Streaming Capture Devices:
      FaceTime HD Camera,0x00200000,1,1,ksproxy.ax,10.00.16299.0334
      Parallels Sound Card,0x00200000,2,2,ksproxy.ax,10.00.16299.0334
      WDM Streaming Rendering Devices:
      BDA Network Providers:
      Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
      Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
      Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
      Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
      Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.16299.0015
      Video Capture Sources:
      Multi-Instance Capable VBI Codecs:
      BDA Transport Information Renderers:
      BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.16299.0015
      MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.16299.0015
      BDA CP/CA Filters:
      Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.16299.0192
      Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.16299.0192
      PTFilter,0x00200000,0,0,EncDec.dll,10.00.16299.0192
      XDS Codec,0x00200000,0,0,EncDec.dll,10.00.16299.0192
      WDM Streaming Communication Transforms:
      Audio Renderers:
      Speakers (Parallels Audio Controller),0x00200000,1,0,quartz.dll,10.00.16299.0522
      Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.16299.0522
      Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.16299.0522
      DirectSound: Speakers (Parallels Audio Controller),0x00200000,1,0,quartz.dll,10.00.16299.0522
      Preferred DirectShow Filters
      [HKEY_LOCAL_MACHINESoftwareMicrosoftDirectShowPreferred]
      MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
      MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
      MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
      MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
      MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
      {78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      {6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
      {64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
      {64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      {64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
      {58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      {5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
      {44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
      MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
      MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
      MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
      MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
      MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
      MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
      MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
      MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
      MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
      MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
      MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
      {20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
      MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
      MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
      MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
      MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
      WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
      MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
      MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
      WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
      MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
      WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
      WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
      Media Foundation Transforms
      [HKEY_LOCAL_MACHINESoftwareClassesMediaFoundationTransforms]
      Video Decoders:
        IntelÆ Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.17.0010.0031
        Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.16299.0248
        DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.16299.0015
        Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.16299.0015
        Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.16299.0248
        WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.16299.0015
        WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.16299.0015
        MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.16299.0015
        Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.16299.0015
        Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.16299.0522
        Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.16299.0015
        HEVCVideoExtension
        MPEG2VideoExtension
      Video Encoders:
        IntelÆ Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.17.0010.0031
        IntelÆ Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 7.17.0010.0031
        H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.16299.0015
        WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.16299.0248
        Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.16299.0251
        H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.16299.0015
        WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.16299.0015
        Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.16299.0015
        HEVCVideoExtensionEncoder
      Video Effects:
        Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.16299.0015
        Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.16299.0015
        VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.16299.0309
        Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.16299.0015
        Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.16299.0015
      Video Processor:
        Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.16299.0637
      Audio Decoders:
        Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.16299.0015
        MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.16299.0015
        WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.16299.0015
        Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.16299.0015
        A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.16299.0637
        GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.16299.0637
        WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.16299.0015
        Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.16299.0522
        Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.16299.0015
        Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.16299.0015
        WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.16299.0015
        G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.16299.0637
        IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.16299.0637
        MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.16299.0015
        Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.16299.0015
        ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.16299.0637
        Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.16299.0015
        DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.16299.0015
      Audio Encoders:
        LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.16299.0015
        MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.16299.0637
        Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.16299.0015
        WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.16299.0015
        MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.16299.0015
        Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.16299.0015
        WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.16299.0015
        Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.16299.0015
        Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.16299.0015
        Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.16299.0015
      Audio Effects:
        AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.16299.0015
        Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.16299.0015
      Multiplexers:
        Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.16299.0579
      Others:
        Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.16299.0248
      Media Foundation Enabled Hardware Categories
      [HKEY_LOCAL_MACHINESoftwareMicrosoftWindows Media FoundationHardwareMFT]
      EnableEncoders = 1
      EnableDecoders = 1
      Media Foundation Byte Stream Handlers
      [HKEY_LOCAL_MACHINESoftwareMicrosoftWindows Media FoundationByteStreamHandlers]
      [HKEY_LOCAL_MACHINESoftwareClassesMediaFoundationMediaSourcesPreferred]
      , , [, Preferred]
      .3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      .ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
      .adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      .adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      .am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
      .amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
      .asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      .avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
      .dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
      .dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
      .ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
      .flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
      .m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
      .mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
      .mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
      .mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
      .mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      .mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      .mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
      .sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
      .smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
      .tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      .vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      .wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
      .weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
      .webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
      .wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      .wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      .wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      .wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
      audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
      audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
      audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
      audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
      audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
      audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
      audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
      audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
      audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
      audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
      audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
      video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
      video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
      video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
      video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
      video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
      video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
      video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
      video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
      Media Foundation Scheme Handlers
      [HKEY_LOCAL_MACHINESoftwareMicrosoftWindows Media FoundationSchemeHandlers]
      , , [, Preferred]
      file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
      http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
      http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
      http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
      https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
      httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
      httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
      mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
      ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
      ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
      ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
      rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
      Preferred Media Foundation Transforms
      [HKEY_LOCAL_MACHINESoftwareClassesMediaFoundationTransformsPreferred]
      {E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
      MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
      {00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
      {EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
      MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
      {A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
      {A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
      {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      {73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
      MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
      MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
      MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
      {63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
      MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      {53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
      MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      {3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
      MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
      MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
      MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
      MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      {33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
      MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
      MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
      MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
      MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
      MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
      MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
      MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
      MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
      {30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
      {30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
      MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
      {0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
      {00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
      {0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
      {00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
      {00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
      MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
      MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
      MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
      MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
      MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
      MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
      MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
      MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
      MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
      {00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
      {00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
      MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
      KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
      {00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper
    • tsiriaks
      Hi Paul_R,
      This is very likely a graphics issue. We have a list of supported/tested graphics card and minimum requirements here
      https://www.ansys.com/Solutions/Solutions-by-Role/IT-Professionals/Platform-Support
      If yours is untested/unsupported, it's like a hit-or-miss whether it would work or not.
      If it worked previously, it could be that there was a Windows update that breaks this.
      I would say, you can try updating your graphics driver to the latest version and also try to see if you have Windows restore point to go back to the state before you installed the Windows update.
      Also, you probably have a higher chance to get it to work on your machine that's running Windows directly over Windows VM on Mac.
      Thank you,
      Win
Viewing 3 reply threads
