ANSYS APDL
    • Rishav Baruah
      How can I remove a layer of elements from the top end of a geometry in ANSYS APDL 19.2?
    • Dave Looman
      Before solution you can select them and delete them with edele,all.  During solution you can select them and kill them with ekill,all.
    • Rishav Baruah
      Ok,thank you ?
    • Rishav Baruah
      How can i select the elements ?
    • Dave Looman
      Let's say the location of the surface is at Y = 20.  Then
      nsel,s,loc,y,20  ! Select the nodes at y  = 20
      esln   ! Select the elements attached to the selected nodes
      edele/ekill       ! Perform desired operation on selected elements
      allsel              ! Select whole model to continue
    • Rishav Baruah
      Thank you very much
Viewing 5 reply threads
