January 24, 2018 at 3:33 pm
Meik
SubscriberHi everyone I need to create a curved rectangular plate model in ansys apdl using coding. Using below particulars:
Material properties: Shell element 281; Poisons ratio: 0.3, Density: 0.0000769, E :206000; Mid sec thickness : 30mm
For the modelling, I need a proper coding, to run analysis under different combinations.
Model particulars:
b (Arc length) - 3106mm; a (width) -350mm (Distance between two arcs); Radius : 2000mm; Angle: 89 degree
As a new user in Ansys using coding finding hard to make a coding for above model. so, if someone could help for the right commands to be used for parameters above would be great.
Thank you
3419
2475
1310
1022
