September 10, 2018 at 10:02 am
tylerleon
SubscriberHi all,
I have a problem with the import of the geometry from an .igs file containing two little tunnels intersecting each other. I just imported the two volumes without performing any boolean operation. The question is: how can I build a continuous mesh at the intersection?
I tried the boolean operations, but while meshing the error "XXX non-adjacent boundary triangles touch. Geometry configuration may be not valid…".
Somebody can help me?
Thanks, Cristiano
September 10, 2018 at 10:07 am
Aniket
Ansys EmployeeHi Cristiano,
Can you try to open this model in SpaceClaim and do these boolean operations there?
You can also export the iges from there to use in APDL.
September 10, 2018 at 10:30 am
tylerleon
SubscriberYes I can try, but I don't know if the problem is the boolean (VOLAP, VGLUE run without problems) or the mesh operations. I need to have a continuous mesh at the intersection and APDL have to recognize that the volumes are separated but the mesh must be continuous…
Thank you!
September 11, 2018 at 12:05 pm
Aniket
Ansys EmployeeIf you do the boolean operation (it is called Combine in SpaceClaim) in SCDM, You will get a clear idea if it is geometry problem or a mesh problem.
If SpaceClaim fails to combine them, you may want to take a look at the model and inspect the reason of failure.
Also, looking at the solids there seems overlap between two solids which must be removed in order to achieve what you want.
If SpaceClaim succeeds in combining the two solids into one, then you can split them again in SpaceClaim and keep them in a single multibody part with Share Topology method set to share. This way it will be 3 different solids but all interfaces will be common, hence mesh nodes will be shared at these interfaces.
September 17, 2018 at 2:33 pm
tylerleon
SubscriberI solved my problem, thank you very much!!!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2590
2080
1315
1108
459
