October 26, 2018 at 8:14 am
tanmaynade
SubscriberHi,
I am facing issues with my program. Listed below. This is form my masters project. Also in what way can I connect the filleted surfaces shown in fig by a weld or just load or stress transfer connection. The link to the program is
https://www.ansysforum.com/forum/ansys-packages/structural/439-apdl-programming-buckling-fea-c-section-cold-formed-steel?view=stream
October 27, 2018 at 9:08 pm
Vitaliy_Degtyarev
SubscriberYou can find more detailed descriptions of the issues in the jobname.err file in the working directory. When I ran your code, I got a warning about only one element violating shape warning limits. The following description was given:
Quadrilateral element 41288 has a pair of opposite edges that are
77.42 degrees away from being parallel. This exceeds the warning
limit of 70 degrees.
You can still run the analysis with this warning, but it is better to change the mesh. I usually select lines and divide them as needed using the LESIZE command, after which I mesh my models using mapped meshing (the MSHKEY command). With this method you have more control over the mesh and get a nice mesh with only rectangular and square elements. You may also want to have smaller divisions for the radii.
If your connections are discrete, you can couple displacements of the nodes that need to be connected using the CP command. If the connections are continuous, you could specify bonded contact between the surfaces.
Hope this helps.
Vitaliy
November 23, 2018 at 1:23 pm
tanmaynade
Subscriberhow to do bonded contact
November 23, 2018 at 1:45 pm
Rohith Patchigolla
Ansys EmployeeHello Tanmaynade,
I have created a simple example to create contacts between two blocks in apdl. It is well commented.
You can understand the basic procedure here and can further apply it to your model.
Also, please go through the help documentation for more reference on any commands used in the script.
fini
/clear,nostart
/prep7
block,0,1,0,1,0,1 !make two blocks touching each other
block,1,2,0,1,0,1
et,1,186 !define a solid element type
mp,ex,1,100 !define some elastic material properties
mp,prxy,1,0.3
esize,0.2 !element size
vmesh,all !mesh all volumes
et,2,174 !create contact elements
keyopt,2,12,5 !bonded contact
KEYOPT,2,9,1
r,2 !real number for this contact pair
et,3,170 !create target elements
asel,s,,,6 !select contact area
nsla,s,1 !select nodes attached to this area
esln !select elements attached to the selected nodes
type,2 !set contact type number
real,2 !set real number for contact pair - one real number for each contact pair
esurf !create contact elements on selected nodes
allsel,all
asel,s,,,11 !select target area
nsla,s,1
esln
type,3 !set target element type number
real,2 !set real number for this contact pair
esurf !create target elements
/solu
antype,0
nsel,s,loc,x,0 !constrain one end of block 1
d,all,all
allsel,all
nsel,s,loc,x,2 !apply displacement on other end of block 2
d,all,ux,0.1
allsel,all
solve
/post1
plnsol,u,x !plot disp x
You can also do this process via ANSYS Classic GUI using Contact wizard.
Hope this helps.
Best regards,
Rohith
November 23, 2018 at 4:23 pm
tanmaynade
Subscriberthanks a lot
November 23, 2018 at 4:24 pm
tanmaynade
Subscriberalso, I'm not able to create e proper mesh for my original program some elements get out of shape?
November 26, 2018 at 3:14 pm
Rohith Patchigolla
Please provide some mesh sizing controls (to refine the mesh at these areas) to get a proper mesh. Also, posting an image of your mesh, where the elements get out of shape would help us provide better suggestions.
Best regards,
Rohith
November 26, 2018 at 4:26 pm
Sandeep Medikonda
Ansys EmployeeTanmaynade,
Please create a new discussion for your question. This discussion is closed. Take a moment to review the guidelines on the Student Community.
2066
1285
1104
459
