Ansys Products
Ansys Products
Ansys API
    • jo9fin
      Hi
      Do any of you know where to find documentation on "InternalObject"?
      The only information i found is that internalobject is for advanced use
       it would be very helpful.
      Regards
    • Aniket
      InternalObjects, as the name implies, are for internal use purposes. These are neither documented nor tested. So it is not recommended to use them in your code as the API may change without any notifications over versions.
      Still, if you want to use it, you can use dir(mesh.InternalObject) and/or help(mesh.InternalObject) to get some pointers.
      -Aniket
