April 10, 2023 at 9:25 am
Greg Ioannou
SubscriberWhat should i do for making them being almost the same?Im finding actual displacement different from equivalent displacement at Hydrostatic results,despite center of buoyance and center of gravity have the correct values.What should i change?
April 12, 2023 at 3:20 pm
Yu Bi
Ansys EmployeeHi, to change the actual displacement, you can change the draft of your structure in the SpaceClaim/DesignModeler by moving the whole structure up or down along the Global z-axis. However, this may change the position of the buoyance centre. To change the equivalent displacement, you can adjust the point mass mass value. You can also choose "Program Control" for point mass, which allows the program defines the point mass mass value based on the actual displacement.
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5356
3345
2471
1310
1018
