November 27, 2020 at 4:16 pm
Kasper96
SubscriberI was reading in the ANSYS AQWA manual, that there is a limit of 20 structures for a hydrodynamic analysis. However, within my analysis I get the error:nFull QTF cannot be calculated for more than 3 structures.nnCan somebody tell me why there is a limit of 3 structures when calculating the full QTF and if there is a way to work around this error?n -
December 1, 2020 at 9:24 pm
KR
AdministratorHello,nANSYS Aqwa can define up to 50 structures in a model, among which up to 20 diffraction structures may be considered as the hydrodynamic interaction structures. However, if the calculation of the difference and sum frequency full QTF matrices is required, only 3 diffraction structures could be defined in the Aqwa model. It is due to the memory limitation in the time domain analysis for storing the interpolated full QTF matrices for up to 200 wavelets in short-crested irregular waves.nThe Newman?s approximation will be automatically applied for estimating the difference frequency second order forces if the full QTF matrices do not exist. Please do not choose the full QTF matrix calculation option if there are more than 3 diffraction structures in your model.nThank you.nKarthikn -
July 20, 2023 at 3:35 am
一博 田
Subscriber我想问一下是否有可能在阿克瓦建立一个完全高于水面的结构
- The topic ‘ANSYS AQWA Full QTF’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
