August 1, 2019 at 3:42 pm
FCNQP
SubscriberHi everyone,
In ANSYS Aqwa Theory Manual Chapter 9, the cable dynamics equations are solved with the help of a mud layer. In the text it is said that this layer has depth "z". Has it is written with the versor notation (^) I assumed this layer has always a depth of 1 [m], but what happens if I am working in [cm] or other units? Does it changes the depth so it is one unit of the whatever units system I am working with? Or is it possible to change the depth of this layer?
Thanks in advance
Francisco
August 5, 2019 at 10:04 am
Ansys EmployeeI suspect it'll use 1m. If you run a test case how does it compare if you use mm and m (keeping the same sizes)?
August 6, 2019 at 12:00 pm
FCNQP
SubscriberIn the tests I've made it does not seem to make a difference the units I use so it seems the mud layer depth must be constant. I am assuming it is 1 [m] regardless of the dimensions of my model.
Thank you for your time
August 6, 2019 at 12:37 pm
Ansys EmployeeYou're welcome, we don't have much AQWA experience in the community so need to rely on some of the non-staff members.
2098
1323
1108
461
