December 1, 2020 at 1:38 am
blieber
SubscriberHello,nThis is more of an interface problem than a simulation problem, but any icons on the Model screen, like point masses, wave arrows, and catenary lines, appear massive compared to the geometry itself. The geometry is about 1.5 meters long, and I cannot find any option to reduce the size of these icons. It doesn't affect the simulation results but it makes it really hard to produce good figures. Is there a way to fix this?n -
December 1, 2020 at 2:43 pm
Mike Pettit
Ansys EmployeeHello, in the Aqwa editor, when you click on the Project object in the Outline tree, you should see some 'Graphics Size Factors' in the Details panel. Reduce the 'Global Control' to change the size of all of the Aqwa-specific graphics.nCheers, Miken -
December 1, 2020 at 5:37 pm
blieber
SubscriberThanks Mike, that fixed it!n -
December 1, 2020 at 9:09 pm
blieber
SubscriberHi Mike,nI have another question. Is there a way to output a Pressures and Motions result as a .csv file?n
- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8808
4658
3151
1680
1470
