ANSYS AQWA wave surface elevation problem
    • naldifirm07
      i am currently modellin a floating breakwater using ANSYS AQWA to determine wave surface elevation behind my model. after i ran the simulation the wave surface before and after are the same, can someone help me? did i miss something during setup?
    • Yu Bi
      Hi, which result were you using to observe the wave surface elevation? In the animation result, the wave surface elevation won't be shown. For the time-domain analysis, you can use the wave surface elevation curve or use AqwaGS to observe wave elevation via animation. For the diffraction analysis, you can also use Aqwa Workbench or AqwaGS to observe the wave elevation graph or use field points to output wave elevation data.
