Ansys buckling unrealistic deformation
    • Kursatbinbas
      I am having a problem with the Eigenvalue Buckling analysis. In every model, buckling deformation results are unrealistic. Even though I analysed a very basic diameter 1m, height 1m cylinder, the eigenvalue buckling analysis deformation results are not correct. In this example, I only applied 1 Newton and the deformation scale is 5. On the other hand, static structural results are totally correct. How can I solve this problem?
    • Ashish Khemka
      Please see if the following video is of some help to you:
      " target="blank">Performing an Eigenbuckling Analysis Using Ansys Mechanical - YouTube
      Regards Ashish Khemka
