September 23, 2023 at 9:52 pm
Shahab Azimi
SubscriberHello All,
I want to define the particle injection in CFX, there is an option for defining the cone angle as shown in the user manual below. But I cannot find where to define the angle in the setings. This option to choose the angle is active in "Cone with Primary Breakup" but not in "Cone" option. Would you guide please.
8.8.2.3. An Example of a Point Cone Using the Dispersion Angle
This following illustration shows how the optionally specified dispersion angle,
, changes the injection type from point cone (Figure 8.4: Point cone with specified cone angle) to point hollow cone (Figure 8.5: Point cone with specified cone angle and dispersion angle). The cone angle is shown as .
September 27, 2023 at 9:36 am
CFD_Friend
Ansys EmployeeHi Shahab,
Make sure that when the 'Injection Method' is specified as 'Cone', the 'Injection velocity' option should be set to 'Velocity Magnitude'. Then only you will find the 'Cone Angle' option under it.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
