March 26, 2022 at 12:37 pm
i.schwarz
SubscriberHi,
I have ANSYS Discovery Structural Physics Add-on (Named User) and ANSYS Discovery Fluids Physics Add-on (Named User) in addition to ANSYS Discovery Simulation (Named User).
I cannot get the Add-on's working on my second machine, although the basic installations is working there. What do I have to do?
March 28, 2022 at 4:20 am
Charudatta Bandgar
Forum ModeratorHello Ingo Schwarz
Let me check this, I will get back to you.
Regards.
March 28, 2022 at 5:16 am
Charudatta Bandgar
If I understand it correctly, when you launch Discovery in refine mode, you are not able to do that. Can you please share a screenshot of the error message you are getting?
Regards.
April 13, 2022 at 10:14 am
i.schwarz
SubscriberCharudatta Bandgar I am surprised that there is no comment available yet. Could you please let me know, what the status is. Thanks.
March 29, 2022 at 4:34 pm
i.schwarz
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi!
I am not sure, if I understand correctly or if I did not make the subject clear. In my Ansys Administration Account I have the add-ons. There are two installations permitted and only one is used. When I start Discovery on a non addressed PC, it will open up and it does not ask for add-on permit. It simply does not take the license, although it is available. Therefore I can put my settings into a run, but it won't proceed, as it says the computer is not capable to run "Analyze Phase" due to a missing adequate graphics card and one line later it says, you need the add-on. So how can I get the add-on active? I attach a screen-shot for your informationThanks
Ingo
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2961
1449
1322
