November 1, 2022 at 12:12 pm
i.schwarz
SubscriberHello! I have - for travelling only - a Microsoft Surface Pro 6 with i7-processor and onboard Intel UHD graphics 620. Due to this Discovery Fluid would not run. That is why I bought the Fluid Add-on, which is supposed to work not on graphics, but on the processor only. However, when I start Discovery Fluid I get the info, that no valid graphic card is available and therefore no run can be started. What is wrong here? Thanks for a prompt feedback. Ingo -
November 2, 2022 at 6:14 am
Atharv Joshi
Forum ModeratorHello Ingo Schwarz
Discovery requires a dedicated NVIDIA Graphics card even for Refine mode. Please go through the Minimum hardware requirements for Discovery products.
Thanks & Regards.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7646
4468
2957
1427
1322
