Discovery Import
Discovery Import
Ansys Discovery Aim 19.1
    • cadmetech05
      How to generate reports with images(Deformation & Stress)?
    • Naresh Patre
      Hello CADME Technologies
      It is currently not possible to generate reports with images.
      As a workaround, you can first export the HTML report from Home > File > Export Report. Then save the results image (In Results task display the required results and Right click > Save Image as) in a folder created by AIM while exporting the report. To insert an image in HTML file, open HTML file in an editor and insert the following line
      where:
      img: It is an image tab to insert image in HTML.
      alt: This Specifies an alternate text for an image. This text will appear when image is not available at specified src path.
      src: Image Path
      border: Boundary with around the inserted image.
