July 9, 2019 at 7:49 pm
Jakubu
SubscriberHi i am new on using ANSYS DISCOVERY AIM 19.2 but i dont know if it will solve my problem or i need ANSYS FLUENT MODULE.
Problem: I need to analyse the air flow going through a solar collector and then exit a solar collector into a drying chamber where products need to be dried with that air. Essentially, into two stages. Stage 1: Atmospheric air (at certain humidity, pressure, velocity, temperature) enters a solar collector whose heat gain is via solar irradiation then Stage 2: air from solar collector enters a drying chamber to remove moisture from the products. Attached is an example of the solar dryer setup similar to what i intend to analyse
I am interested in evaluating the performance of the solar dryer (collector and drying chamber), fluid behavior within the solar dryer and around the product to be dried. -
July 9, 2019 at 11:00 pm
Sandeep Medikonda
Ansys EmployeePlease go over the videos provided on ANSYS How to youtube Channel (such as these)
Additionally, Here are some useful links:
July 10, 2019 at 10:02 am
Jakubu
SubscriberI have already watch that video and it is not giving any info relevant to my question. Perhaps you must read the problem statement again.
October 8, 2020 at 12:30 pm
Abdmen
Subscriberhope you are doing good. please did you find how to simulate your system, specially the drying part? and thank youn
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3812
2607
1853
1244
600
